Schedule problems
RalfB
Schedule problems
Post by RalfB »
Hi there,
I'm using the latest Version of SyncBackSE and I do have the Problem that it is impossible to create a time schedule. S there is none configured yet it's asking me for the Adminstrators Password. I enter it (and it's correct - trust me :) ) getting a reply that the requested file could not be found.
Is there somebody having an idea what's wrong?
Thanks in advance!
Ralf
Re: Schedule problems
If you receive 'The system cannot find the specified file' error when creating a schedule task then try the suggestion given here:
https://help.2brightsparks.com/support/ ... 3000336202
