What are the differences between the Windows and Windows 10 styles. Is it just the new colors that were added or are there other differences? I looked in the FAQ's on the web site and in the program Help, but couldn't find anything on this.
Bill
Windows vs. Windows 10 styles
- Advanced
Re: Windows vs. Windows 10 styles
Any help would be much appreciated. I am really just wondering why there are two styles listed... Windows and Windows 10. What are the differences? Why would I use one rather than the other?
Bill
Bill
The icons/graphics and buttons are different in Windows and Windows10 (or Window10 Dark) styles as styling is removed in Windows mode. One important difference you notice in Windows mode is, the Shared Settings menu, Search, Help options are not available on the caption bar on the profile’s modification page. Therefore, to view help file you can either press F1 or click on Help button at the bottom of the Modify page. For Search, select the Search tab from the left panel on the Modify page. And for Shared Settings, click on the Shared Settings button on the top left corner of the Modify page (next to burger menu).
- Advanced
Thanks for the reply. This helps me understand what the differences are. Should this be documented in the Help somewhere? Or in the web site FAQs?
You mention:
Bill
You mention:
I am not seeing this. Where is the button? I have included a screenshot of what my Modify window looks like. I don't see this button.For Search, select the Search tab from the left panel on the Modify page. And for Shared Settings, click on the Shared Settings button on the top left corner of the Modify page (next to burger menu).
Bill
- image1.jpg (84.55 KiB) Viewed 24323 times
I attached screenshots showing the Search tab and Shared Settings button. Note you can share the settings on the following profile settings pages, hence the Shared Settings button is visible only on these profile setting pages:
Auto-close
Backup of email
Cloud
Emailing the log
FTP
Network
Variables
When, Program
Zip filter
Auto-close
Backup of email
Cloud
Emailing the log
FTP
Network
Variables
When, Program
Zip filter
- Shared Settings.png (76.86 KiB) Viewed 24306 times
- search.png (44.86 KiB) Viewed 24306 times
- Advanced
@Swapna
Thanks for the explanation. I see how it works now.
Bill
Bill
