1) At some point my error logs stopped emailing. I had no idea. Only because 1 PC was offline for a week did I bother to check to see if program ran because I should have been getting a daily error but never did. Sure enough, the program failed because the PC was off line. So, I checked the 4 other back up profiles and they all 5 give this same error!? So what do I need to do to fix? The settings have been working before but I have no idea when they quit working. Dangerous!
2) How can I set SyncBack to notify me somehow when errors exist in addition to mailing the log? Produce the error log and let it sit on the desktop until I clear it next time I log into that PC?
Unable to send email: Failed to get access token??
Re: Unable to send email: Failed to get access token??
Can you please send your profile configuration and a screenshot of the log that appears when you click on 'Test Email Settings' button to [email protected] for investigation?
Just sent. Thank you.Swapna wrote: ↑Mon Jun 24, 2019 3:30 amHi,
