Should SyncBack SE copy open Veracrypt sontainer?
John Gray
Post by John Gray »
I'm now on Windows 10 v1903 64-bit and SyncBackSE v 8.8.0.0, and have been horrified to find that a usually-open Veracrypt container file hasn't been copied from source to target for nearly a year of weekly SyncBacks!
The SyncBackSE profiles were imported from Windows 7 32-bit when I moved to Windows 10, and the copying seems to have worked on W10 v1803 (for some time at least) but not on v1809 and v1903.
Should I have done something to the profile(s), or otherwise specified something which would continue to facilitate the copying? The Veracrypt file is 'ticked' in "Choose sub-directories and files", and the tick box is followed by two file icons.
Thanks for any help!
Re: Should SyncBack SE copy open Veracrypt sontainer?
Please generate/submit a support zip with debug logs of the profile run to [email protected] for investigation. Full instructions for creating and submitting the support zip are given here:
https://help.2brightsparks.com/support/ ... 3000335603
If your Zip is over 20MB, contact us for alternate instructions, advising the actual size. Do not try to attach to the ticket!
