Will SBSE back up an IMAP .ost file while Outlook is running, or do I need to close the program first?
Backing up Outlook IMAP .ost file
Re: Backing up Outlook IMAP .ost file
SyncBackSE supports copying open/locked OST files while Outlook is running. However, it requires the Windows Volume Shadow-Copy Service (VSS) to be working on your PC, and the pre-requisites for using VSS are satisfied:
https://help.2brightsparks.com/support/ ... 3000335703
As we leverage on VSS to copy open/locked files, it would require SyncBackSE to be installed on the same PC system that the open/locked files are stored (one of VSS's requirements). So, please test to see if it works?
OK thanks.
I am looking now at the version comparison page https://www.2brightsparks.com/syncback/compare.html
and the last item in the Supported Protocol section is "Backup Emails" and it says that only SyncBackPro can do this.
What does this refer to?
Please read 'Backup email messages' article for details about Backup Email feature:
https://2brightsparks.freshdesk.com/sup ... 3000336184
OK thanks.
