I have a group profile which contains some base profiles.
Now I want to change the order of these base profiles.
I guess I should be able to mark a certain profile and click on the "up" or "down" arrow button at the right to move the profile.
However the up+down arrow buttons are disabled/greyed out.
How can I enable them?
Peter
How to change order of Profiles in Group profile? up/down arrows disabled
- Knowledgeable
Re: How to change order of Profiles in Group profile? up/down arrows disabled
You need to uncheck "Run profiles in Parallel (at the same time)".
- Enthusiastic
Thanks for the tip, it works, but SyncBack should still give the option to reorder the profiles, even if "Run Profiles in parallel" is checked. I don't see why such a limitation.
