Hi, I am using syncBackFree version. Now, I need to run a profile at windows logoff. Can you confirm that the SE version can run a profile at windows (10) logoff ?
Thanks.
Version SE run profile at logoff ?
Re: Version SE run profile at logoff ?
Yes, the option to run a profile on Windows shutdown/logoff is supported in SyncBackPro and SE V9 version.
If you do not own a copy of SyncBackPro/SE V9 and wish to test it's functions, you are welcome to try our fully functional SyncBack, which we offer a free 30-day evaluation.
SyncBackPro:
SyncBackSE:
SyncBackPro:
SyncBackSE:
Hi, I install the SE version. But, i don't found where I can program to run a profile on Windows shutdown/logoff.
Is there somobody to help me ?
I am sorry, I found. I was looking in "modify the scheduled task", I did not see the connection connection tab.
