Hallo 2BrightSyncs
I have looked on the forum, and I cannot see this problem.
Install SyncBackSE in a directory c:\ProgramFiles\SB94, want to update, so delete directory c:\ProgramFiles\SB94 !!!
Update to new version, install, and the installation defaults to the same directory c:\ProgramFiles\SB94
I don't want to install to this directory. I want to install to c:\ProgramFiles\SB95
Workaround : ReInstall to c:\ProgramFiles\SB94, win10, settings, uninstall, then install new version to new folder.
Would like : Installation script asks if install directory should be previous directory or new.
Thanks, Shaun
Bug : Cannot change installation directory
- Dragon
- Dragon
Re: Bug : Cannot change installation directory
Admin, please move to support_ticket, thanks.
