move licence
move licence
Can i move my se licence from one pc to another pc,will the same serial number used for old pc work in new pc or should i buy a new licence
Re: move licence
You can completely move your se license from one computer to another. Rest assured that the same serial number used for the old computer will work properly on the new computer without you having to buy a new license.
Re: move licence
You will not need to buy a new license because you can completely move your se license from one computer to another. The same serial number used for the old computer will work properly on the new computer.
Re: move licence
Re: move licence
Are there any specific steps or procedures I need to follow to successfully transfer my SE license from one PC to another?
- Experienced
Re: move licence
Hello!
You can usually transfer your SE software license to a new PC, but check the license terms first. Deactivate it on the old PC, then install and activate it on the new one using the same serial number. If you face any issues, contact customer support for assistance.
Mike Taku.
