restore a Mirror backup
SBF_User
Post by SBF_User »
I'm been running a 32bit SyncbackSE V8.5.122.0 for several yrs. I also own a newer version but Ver 8 has worked so well haven't needed to install the newer purchase.
All of my Sync backups are Mirror, I don't do any two way sync. I want exactly what's on the source to go on the destination drive, nothing less nothing more and SyncbackSE mirror does that faster than other types of backups.
* Soon I may have to restore a mirror and I'm a bit apprehensive as to how that plays out.
* My question is: My backup Profile has mirror settings, so if I select restore from the profile menu, will it mirror everything in reverse?
* In other words everything on the destination drive path will be mirrored to the original source path (matching the dest)?
* Or is there some questions or settings I've got to be prepared for when this happens?
Re: restore a Mirror backup
You can see what it is going to do by right clicking on one of your Mirror profiles and selecting "Simulated Restore".
MikeTaku
Experienced
Experienced
Post by MikeTaku »
Just saw this thread, can you please tell me when I restore from a mirror backup in SyncbackSE, will it mirror everything from the destination drive back to the source, and are there any settings I need to consider beforehand?
