I have versioning switched on, and I have adjusted the number of versions to keep down from 3 to 2. I've run the backup a couple of times, but the version 3 generation files have not been deleted.  Is there a way to force this to happen, or do I need to delete them manually from the $SBV$ folder?
I am using SBSE version 7 (yes, I know it's really old, but it works for me)
Thanks, David
