I am "backuping" my PC on a NAS and I think it would be more efficient to run the differents profiles I have in sequence rather than in parallel. Is it possible to imagine a global parameter (checkbox ?) to run all the selected profiles in parallel or in sequence ?
May I suggest making a group profile. Add your backup profiles to the group profile in the order you want them to run top down. Don't check the box to run them in parallel and boom done.
