Forum Editor Glitch (or Undocumented Feature)
Sn3akyP3t3
Post by Sn3akyP3t3 »
I've discovered in this forum the editor is not creating Ordered Lists correctly. Both Lists and Ordered Lists create the same template text and end up just being Lists. One has to manually edit Ordered Lists by adding the necessary number for it to be treated correctly. I suggest restoring that default setting to include the missing single one character.
Should be easy to recreate by just creating a new post or reply to mine and see for yourself.
  • This was created using List.
  • This was created using Ordered List.
  1. This is an example of a corrected Ordered List.
  2. To fix this just add a one like so
    Code: Select all
     [list=1]
