Synchronize should delete older files and copy recently modified files
kw99999
I use sync software to keep my user files on multiple PCs identical. Files can be created or deleted on either PC. If I delete an old file that hasn't been modified within the last few days in either the left or right PC, I would like it to be deleted from the other side. Recently changed files in the left or right but not in the other should be copied. Can this logic be added to the Decisions options for files?
