I just registered and first of all I must congratulate you for the magnificent program that you have developed.
It is intuitive to use and tremendously practical to keep Backups up to date.
However, I would make a suggestion to you, which is that:
"THE EMPHASIS COLOR OF THE TITLE AND WINDOW BORDERS SET BY WINDOWS WILL BE APPLIED TO THE WORK WINDOW - NOW IT IS ONLY APPLIED IN THE HELP - IF IT ALSO HAS A DARKENING IN THE ZONE FREE OF FUNCTIONS IT WOULD AVOID CLICKING ON A FUNCTION"
In very dense Jobs, with many windows opened, it gets lost and many times you click on "Serial Number" or "Help"
Thanks and regards,
Re: COLOR OF THE TITLE AND WINDOW BORDERS
Thank you for your suggestion. In order to properly understand the issue please send us some screenshots at [email protected]
It's much easier seeing the problem than trying imagining it.
