is it normal, that if mirroring a partition the emty folders are copied at last in the mirroring process?
So
folder1 with files and 1 empty folder named "emptyfolder"
folder2  with files
folder 3 with files
are copied, but not the folder "emptyfolder" in the folder1. After copying folder 3 with it´s files, the file folder1\emptyfolder is copied.
(the action: if empty folders only exist on the source they are created on the destination is set)
Mirroring files - empty folders are copied at last?
				o0Julia0o
				MikeTaku
- Experienced
Re: Mirroring files - empty folders are copied at last?
Hello, I hope this message finds you well and that everything in your world is flowing smoothly. Wishing you a productive and peaceful day ahead!
Yes, it's normal for empty folders to be copied at the end of a mirroring process. The software focuses on files and non-empty folders first since they contain important data, then creates empty folders afterwards, as you've enabled the option to mirror them. This behaviour is typical and can be adjusted in some settings if needed.
Mike Taku.
Mike Taku.
				shital
Hi everyone,
I was curious about the same thing. It's good to know that empty folders are copied at the end as part of the mirroring process. If there's a way to adjust this behavior in the settings, I'd love to learn more about it
