On the log screen (while modifying a profile) one of the options says "If the user cannot be prompted to choose an action then:"
This was a bit confusing at first. We assumed that any prompt would be recorded (for example, a prompt warning your about to delete all files on destination or source when run attended). That's not the case.
The help file does clearly explain it's referring to file decision prompts, but just thought we would point it out in case you wanted to make the GUI any more clear.
Clarifying an option within the Log settings
- Knowledgeable
Re: Clarifying an option within the Log settings
Um - which version?
I'll pass it to the developer, but dialog changes require lots of translation work (x 18...), so we do tend to rely on users pressing F1...
- Knowledgeable
Oh, good point. Sorry about that.
Version 6.0.0.15
Didn't think that option was there in V5, but maybe it was and just never noticed.
I know it's only in V6 (and now so do you
) - and now so do other people reading it
- Knowledgeable
