When using windows scheduler you can tell a job to start at a certain time and run each hour for a set amount of time.
Such as:
Job starts at 6:00am and runs each hour for 12 hours. It would be nice to be able to do this when setting up a job with SyncBackPro.
Scheduling option missing
Dave Wilkins
Re: Scheduling option missing
Um - you can? Using the Repeating settings?
This assumes you are using Vista or later, which you haven't actually said (Windows Scheduler has two different versions)
mishelp
I found it.
ShockDiamond
Damnit. I just posted basically the same question but I already found the options.. Not sure why I've never noticed indefinite hours, minutes and seconds there in about 2 years.. haha.
