I have been using SyncBack Pro for quite some time and as the need for increased backup intervals is needed, it leaves me dry.
I can schedule for daily backup, weekly, monthly.. But what about hourly or by minute? These options do not appear to be incorporated.
Backup software should provide maximum protection against loss of data, therefore, I suggest scheduling features for hourly and "realtime" by minute be added. As long as it's a direct backup that checks file versions and updates only new ones, the computer resource overhead should be minimal.
In our software (which leverages the Windows Task Scheduler) you can set a Task to run maximum once per day, but you can leverage the Repeat settings 'within' that to achieve any frequency you like. It depends on your OS and which version of our software you are using exactly where you would find these, but if you cannot see them immediately, try looking under the Advanced button
