File copying
howfen.lad
File copying
Post by howfen.lad »
I have recently reinstalled SyncBackFree after reinstalling Windows and it doesn't work the same way any more.
I use it as "Mirror" to back up files to an external NAS drive. It used to just transfer files that had been changed but now it transfers all files every time. This appears to be because the files on the external drive are given "new" dates when they are copied so they always appear to be different.
From the help files, I see that this is a possibility and I have checked the requisite box under "Copy/Delete/ Advanced", but this doesn't seem to make any difference. This never happened before.
Any advice please?
Re: File copying
Sounds like your NAS is failing (or, refusing) to stamp the copied files 'as of' the same date/time stamps of the Source files. If the target is under Windows' control (e.g. another Windows PC, a USB drive inserted in that PC or the PC running SB...) this should be performed (by the main Windows 'copy' API that SB calls) anyway, with no 'forcing' required. But, as the legend (and the Help) for that 'force' setting states, this may not happen for some resources under the control of another system (e.g. firmware, different OS...), so you can try using the option you mentioned, This invokes a separate/additional API that specifically tries to set this stamp as a separate operation, but it may not work if the NAS firmware (or equivalent) does not cooperate.
Are there any Warnings in your log about a failure/refusal to set date/time? (NOTE: IIRC, this would only happen while using the 'force' setting, and wouldn't change any Result value - thus you need to check the log). Unfortunately, NAS firmwares that simply ignore the 'force' command (or 'silently fail', without generating an error message) are not unknown. But it's not a known issue with SB Free/SE/Pro itself, or you would presumably see a lot more posts like yours (maybe daily...), as it's obviously a critical aspect for backup software. Easy way to test is making a temp profile to copy a few files from somewhere on your PC to another (temp) folder on your PC (or, a flash drive, etc). I suspect you will find that works fine; if so, the 'suspect' is fairly obvious.
IIRC, it may be that the Safe Copy process (details in the Help, same Copy/Delete -> Advanced page) isn't correctly supported by the NAS, so that the just-forced date/time-stamp is lost again during the rename process. You could try unchecking that option to see if it helps. If it makes no difference, turn it back on (see Help on option for why)
howfen.lad
Re: File copying
Thank you, Cliffhanger, I will experiment!
