SyncBackFree BETA V7.6.27.0
Post by mickyj »
A new BETA of SyncBackFree is available for download:
It contains the following changes:
New: In file and folder selection window can now open selected folder in File Explorer via pop-up menu
New: In file and folder selection window there are new main menu options to ignore or include all new files and folders
Fixed: Visual issues related to high DPI
Fixed: Search in profile configuration
Fixed: GROUPNAME and VISUALGROUPNAME variables were not set to an empty string if not run as part of a group
Fixed: CRITICALERROR variable now set in Run After
Fixed: The File and Folder Selection tree was not using the display filters
Updated: The main menu option to only show groups and profiles not in group is now enabled by default
dmh125
Re: SyncBackFree BETA V7.6.27.0
Post by dmh125 »
I'm getting an error 404 when trying to download the beta. This is what my UI looks like now - Title Bar and menu bar look good, rest of text is tiny. Can't change size of SegoeUI font (tells me must be between 6 and 6). Windows 10 64 bit 1607, 4k resolution, 150% display scaling.
Post by Kostas »
dmh125 wrote:I'm getting an error 404 when trying to download the beta. This is what my UI looks like now - Title Bar and menu bar look good, rest of text is tiny. Can't change size of SegoeUI font (tells me must be between 6 and 6). Windows 10 64 bit 1607, 4k resolution, 150% display scaling.
The reason for the 404 is because a new release (V7.6.28.0) is available. You can download it from http://www.2brightsparks.com/download-syncbackfree.html
