Error (5); log lists Recovery folder that doesn't exist
silt
Post by silt »
Hi. I've been using SyncBackFree for years to keep my storage drives in sync, and today I ran into an error that I can't figure out. The error is "Scan failed (5): Access is denied", but in the log it seems to be listing a folder that doesn't exist on the drive. I'm using Windows 10 64-bit, and my storage drives are E: and F:. The error log looks like this:
Left F:
Right E:
3:44:06 PM E:\Recovery\ Scan failed (5): Access is denied
But there is no "Recovery" folder on the E drive. Note, I do in fact have "Hidden items" checked in the View options. If I scan each folder on the drives separately, there are no differences, so I believe my files are in sync. But I can't figure out if SyncBackFree is reporting a folder that doesn't exist, or if the folder actually does exist but for some reason I can't see it.
Any help or suggestions you may have will be appreciated. Thanks.
Re: Error (5); log lists Recovery folder that doesn't exist
G I Y F
http://www.dslreports.com/forum/r286410 ... den-folder
Suggest read all of it. Note the post near the end, re '7Zip sees all' - so does SyncBack...
