Copy from different folders
gtsolid
Post by gtsolid »
hello
i'm new and i'm trying to configure a mirror backup.
in source folder i have a lot of .pdf in different folders, in destination folder i have some .pdf, no folders.
i wish to take from source updated pdf and substitute them in the destination (matching names), without modifying any other files.
how can i do it?
Re: Copy from different folders
By default, SyncBackFree in each run scans the Source and Destination locations to detect the file differences (using Last Modification date/time stamps, size etc.), and copies only new or changed files from Source to Destination without overwriting unchanged files.
Please refer to this link for more details:
http://support.2brightsparks.com/knowle ... nged-files
However, SyncBack compares the files/folders on your Source with the same file/folder structure on your Destination.
For example: If you have configured your Source path as “C:\MyPrimaryData\” and Destination as “D:\MyBackupData\”, then SyncBack will compare the file “C:\MyPrimaryData\folder1\file1.pdf” with “D:\MyBackupData\folder1\file1.pdf”, but it does not compare “C:\MyPrimaryData\folder1\file1.pdf” with “D:\MyBackupData\file1.pdf”.
If SyncBackFree can’t locate file1 in “D:\MyBackupData\folder1\” (or it finds, but it detects the Source and Destination files are different) then it copies file1 from C:\MyPrimaryData\folder1\ to D:\MyBackupData\folder1.
