Add further source and destinations folders to Profile Setup?
Biff
Post by Biff »
Can I add here further source and destinations folders:
Re: Add further source and destinations folders to Profile Setup?
You have posted your question in a wrong section. As your screen shot shows you are using SyncBackFree, you should post your questions in SyncBackFree section (instead of SyncBackPro). So, I have moved your post to SyncBackFree section.
However, to answer your question – A profile in SyncBackFree can point to only one Source and one Destination location. So, you may have to create multiple profiles to backup files from different Source and Destination locations.
Biff
Post by Biff »
Hello Swapna,
Very sorry for that. And thank you for moving the post.
Alright, I understand, so create new profiles then.
Many thanks again
Gary A
Post by Gary A »
To take it a step further, after I created my individual source/destination profiles, I then created a single Group profile and added the individual profiles that I wanted to run at the same time, to save steps.
Biff
Post by Biff »
Alright, yes, that is a good procedure, thank you very much, Gary A.
