How do I "Pause" or "Stop" a profile
thewolfe
Post by thewolfe »
How do I pause or stop either one or all of my profiles.
I've right-clicked and either Pause or Stop a profile but nothing happens.
thewolfe
Re: How do I "Pause" or "Stop" a profile
Post by thewolfe »
There is no answer to this question?
To Pause or Stop a running profile – you can either select the profile from SyncBackFree’s main-interface > right click and choose Pause/Stop from the pop-up menu or you can click on the 'Pause' or 'Stop' button that appear at the bottom-left of the SyncBackFree main-window (near the progress bar). I tested both ways using the latest version of SyncBackFree (v7.6.36.0), but I couldn’t reproduce your issue.
If you are not using the latest version of SyncBackFree then please upgrade to v7.6.36.0 and re-test the Pause/Stop feature to see if it helps? You can download and install the latest release from here:
If the issue persists, please let us know your Source and Destination locations and steps to reproduce your issue.
thewolfe
Post by thewolfe »
I right click on one of the profiles the menu drops down, I choose "Pause", the menu goes away but there is no indication (icon) that is is going to be paused. I did try it anyway but ran when next scheduled.
I'm running V7.6.39.0 (Windows 6.1.7601
Must be doing something wrong but your instructions are pretty simple.
The only Profile that is paused is my Firefox profile because the program is open and it will run as soon as I close it.
Thanks for the post, what's next?
Please submit a support ticket with your profile configuration (right click on the profile > Export Profile) and the steps to reproduce the problem using the Contact Support links in this article for further investigation.
