Protecting NAS against ransomwear
brilliantweb
Post by brilliantweb »
Hi
I have a NAS attached to a LAN via a switch.
The individual PC is set to backup to the NAS using SyncBackFree.
The PC was infected with Locky, which encrypted all the files on the PC, and then also reached into the NAS and encrypted the backup files as well.
Is there any configuration of PC / NAS / SyncBack that would allow SyncBack access to the NAS for backup purposes, without the ransomwear gaining access to the NAS?
Brendon
brilliantweb
Re: Protecting NAS against ransomwear
If I set the destination NAS connection via FTP, and set a different password to the PC administrator password, and remove all network share links to the NAS, would that prevent the ransomware from gaining access to the NAS?
Brendon
Sorry, but there is no setting in SyncBackFree/SE/Pro to stop ransomware from gaining access to your NAS drive. Note that ransomware itself can easily access and encrypt files stored on a mapped drives or USB drives for which a drive letter is assigned and drives that can be accessed directly without a password. Therefore, we suggest backing-up files to an offsite FTP, FTPS, SFTP server or Cloud server (like Amazon S3 or Azure).
I would suggest you to read these articles which provide suggestions on how to protect your important data from ransomware or cryptolocker:
http://www.2brightsparks.com/resources/ ... mware.html
But please note that some suggestions given in above articles requires using either SyncBackPro or SE. If you want you can test with SyncBackSE/Pro, which we offer a free 30-day evaluation. You can download and install latest version of SyncBackSE/Pro from here:
brilliantweb
Hi
Thanks for those links.
My client is in a rural area with very poor Internet connectivity, so cloud backup is not an option.
The client has a long history of being the point of failure for any backup process that requires manual intervention, so the solution has to be fully automated.
If I use FTP, and set the destination to a local IP on the network, would that work?
The NAS has a fixed IP, and accepts inbound FTP connections.
Brendon
cowelln
Post by cowelln »
Here are some interesting tips: http://csharpner.com/blog/index.php/how ... ansomware/
Perhaps we need a Linux version of SyncBack, but it's basically about making sure that the ransomware doesn't have access to everything.
