design icon changed after runing a profil
graynon
Post by graynon »
Hi , for some of my directories i have change the standard icon by an another one.
after runing the saving profile , design icon on the saving support have been changed for the standard design.
how to have the same design on the saving support ?
thnk for your help
Georges
Re: design icon changed after runing a profil
1) You need to be copying the DESKTOP.INI files for those folders, and by default SB will Filter them out. Check your profile's Filters, and if necessary Remove the entry
*\desktop.ini
from the filters on right ('...NOT to copy...'). You will probably be prompted to include many DESKTOP.INI files as you Exit out of that procedure (you can say 'Yes To All' to speed this up)
2) you need to set SB to configure the Destination copies to use the DESKTOP.INI files that will now be copied.
Modify profile > Search (near foot of tree on left) > "desktop" > click 3rd hit
This gets you to the Copy/Delete > Folders settings page which has an option (2nd from bottom) to configure the copied folders to use the INIs. Press F1 on Folder page and read the Help on that aspect, especially how MS do not only use DESKTOP.INI to store such information. If it does not seem to work, it is possible you may have to wipe your backup and re-create it with the Filter removed and the config option set (that is, it may not work for Dest folders that already exist). All you can do is try it, both ways if necessary. I do not use custom icons, so can't test that. For the same reason I can't assist further if it doesn't work for you, but hopefully the above may help.
You will probably be prompted to include many DESKTOP.INI files as you Exit out....
should read '...as you OK out' (there is no Exit button; do not use Cancel, or it will...)
graynon
Post by graynon »
Hi Cliffhanger ,
thanks you for your message.
First, i must translate in french for a better understanding ...
second, asap i will try , i will keep you informed
Georges
graynon
Post by graynon »
Hi
- I have changed option about desktop.ini in my profile ok.
- You asked me to search "dekstop" , but this term is not found (neither "bureau" in french , I think you mean "Directory" .
So I have found directory and I have put on "when the file desktop.ini (used by W) is copied,
the directory is modified consequently to permit W used it"
I have run again the profil , but icon are not changed.
( for information when I make copy/past of a directory under W, the icon is also not changed.)
So , i have wipe all files to the target and I have run the profil.
The résult is now OK.
but as your said , due to how windows work, for next change , W will not update icon modified.
thank you very much for your assistance.
Best regards
Georges
