Freeze with notification update
slowdive
Post by slowdive »
Hello.
I use SyncBack for a long time. Every time there is a new update i get the notification and the program freezes. If i try to click ok or cancel nothing happens. I have to open task manager to close it.This didn't happen once or twice. It's always happening, on different laptops, with different versions of windows 10, with different versions of Syncback...Any solution for this small problem? Thanks
Re: Freeze with notification update
I conducted some tests on Windows 10 PC, but I couldn't reproduce your issue.
Can you please submit a support ticket with steps to reproduce the problem (and screen shots showing the freeze) using the Contact Support links in this article for further investigation.
slowdive
Post by slowdive »
I will do that when there is a new update. Thank you
