Possible solution to silent fail on scheduled profile
jeverett
Post by jeverett »
I recently installed SyncBackFree 7.6.45.0(en) on my Windows 10 (64-bit) desktop. When I tried to setup and test a schedule for a synchronize profile, nothing happened. I found several 10016 events in my event log that were associated with the DCOM object request broker. A bit of Googling turned up the following site:
https://shauncassells.wordpress.com/201 ... 160-and-a/
Quoting from the start of the article: "Windows 10 Event 10016 Fix: The application-specific permission settings do not grant Local Activation permission for the COM Server application with CLSID {D63B10C5-BB46-4990-A94F-E40B9D520160} and APPID {9CA88EE3-ACB7-47C8-AFC4-AB702511C276} to the user NT AUTHORITY\LOCAL SERVICE SID (S-1-5-19) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool."
The rest of the article provides a straightforward repair procedure. Apparently something goes awry in the Windows installation, such that the request broker ends up owned by the TrustedInstaller, rather than the Administrators group, and this results in permission problems when running a schedule. The fix is to change the ownership to Administrators, then use the DCOM configuration tool to add SYSTEM to the owners of the request broker.
The SyncBack profile ran on schedule after doing this.
One caveat: I have a Mac Mini with bootcamp dual-booting into Windows 10, and I found the same problem, with TrustedInstaller owning the request broker. However, prior to making the changes recommended in the article, I created a profile, and tested a schedule, which appeared to work. Aside from the hardware differences (I assembled my desktop from parts (e.g., gigabyte motherboard)) the only thing I can think of that's different between the two is that the desktop is running Windows 10 AU (build 14393), whereas the Mac is still running Windows 10 build 10586 (it keeps failing on the AU update).
-John
