Problem with automatic task
dodero4
Post by dodero4 »
Hi i'm italian and sorry for my not correct eng, i configured filezilla server on pc 1, and in with pc2 syncbackfree, the connection with server is good, correct working, but if i configured repeat task on 5min to backup on server do not start, only working if i press start running the server running win7 64bit and second pc synbackfree with windows 10 64bit, I hope I explained myself.
dodero4
Re: Problem with automatic task
Post by dodero4 »
Thanks for posting, problem solved with activate the task in advanced mode and non in easy mode.
