One Profile - copy from different drives?
mouse
Post by mouse »
I understand that I can set up many profiles and as part of the profile, select which folders or subdirectories are included. Just wondering if it is not possible to set up one profile to include specified folders from drive A, other folders from drive B and some files from Drive C - assuming these all belong to a certain project and you wish to keep them backed up in one location? At the moment it seems to me that each profile can only have one drive, so that I need to set up a list of profiles to achieve my combined output.
Conrad Chung
Re: One Profile - copy from different drives?
Post by Conrad Chung »
Multiple drive selection support (within a single profile) is only supported by SyncBack Touch (available in SyncBackSE/Pro) or by using the AllDrives script (scripts only supported in Pro).
For SBFree users, one workaround is to create different profiles (for each drive) and run them as a Group, so that whenever the Group runs, all profiles within the Group runs in sequence.
mouse
Post by mouse »
Conrad, thanks for your reply.
While it may be a bit more convoluted to set this up via a group, I think your suggestion as a work-around is fine for me. As long as I can run a number of backups that belong together with one command that will be fine. I was just worried that if I have too many individual profiles and they need to be triggered individually daily/weekly/monthly it's bound to cause problems with some forgotten. Using the group feature I can avoid that. I am not sure I am daring to try scripts and have not yet decided whether to to upgrade to Pro or SE. Will have a look at touch to see what benefit that would bring.
