Need to determine which files are not being mirrored
Maestr0
Post by Maestr0 »
I set up new mirror job that included over 97,000 files. After completion of the job, there is a significant difference in the total file count and size of files between the source and destination. I know there is a "ignore" file parameter that keeps some files from being mirrored. I can account for 60% or so of the file difference by searching the source for some of the obvious files, like thumbs.db.
I’d like to know if there is a way to create or view a simple list of ignored files to see exactly what files are not being mirrored without having to install the SE version and re-running this 10 hour mirroring job over again. Is that possible?
