Moving profile settings to another directory
tramp20
Post by tramp20 »
I want to move the profile settings to another drive (e.g. from
C:\users\NNN\appdata\local\2brightsparcs\syncbackfree to E:\users\NNN\...
I found your technical article http://support.2brightsparks.com/knowle ... are-stored
but I don't understand this sentence:
" To move an existing profile you must Export it, delete it, change the setting where to put new profiles as appropriate, then re-Import it."
Where can I change the setting where to put new profiles as appropriate? The expert preferences doesn't allow this.
