Is there a way to tell SyncBackFree not to consider a backup as failed merely because it couldn't change attributes on a subset of files? I can see flagging this as a warning, certainly, but not a total failure. I've never seen any other backup package with the "failure threshold" quite so low, including even commercial / enterprise software like ShadowProtect, Backup Exec, Networker and Avamar (much less desktop backup packages).
Thanks.
"Failed to change attributes" = failed backup?
Re: "Failed to change attributes" = failed backup?
To better assist you please submit a support ticket to [email protected] with your profile configuration and support zip as per the instructions given here:
