I am using SBF to synchronize a number of local folders to google drive. It run`s every 15 minutes, and simply synchronize both folders.
I want SBF to also delete files that were deleted on one of the location, whether it`s the local folder or the google drive folder. However, I did not find a way of doing so. Currently, if I don't delete the same file from both folders in the time frame between 2 syncs, it will be copied again.
I thought about using the mirror method, but as far as I understand, it will be a classic A -> B situation, which does not feet the two way street way I require.
Please assist me. I appreciate your help.
Thank you,
Noam.
Deleting files in the synchronization method
Re: Deleting files in the synchronization method
In SyncBackFree, the Sync profile type is called Basic Synchronization, and this is different in commercial version (SyncBackSE or SyncBackPro) which is called Intelligent Synchronization, or Intelligent Synchronizationhronization.
The key difference is that BasicSync does not keep a database to remember which files are deleted or changed on either side like Intelligent Synchronization does. Therefore, in a BasicSync profile if a file is present on one side you can either configure the profile to delete the file from that side or copy it to the other side. However, a Intelligent Synchronization profile (in SyncBackSE/Pro) copies/deletes files in both directions. It also keeps a history of where files were during the last synchronization. Please read this link for more details about Basic Synchronization and Intelligent Synchronizationhronization in SyncBack.
http://www.2brightsparks.com/syncback/h ... ronize.htm
If you wish you can test with SyncBackSE/Pro, which we offer a free 30-day evaluation. You can download and install latest version of SyncBackSE/Pro from here:
