Hi everyone,
I'm new to the forum, I try to read all the help and to search inside the forum, but unluckly I didn't find anything regarding my question....
I need to hide a task
I'm sincronizing my data on a usb driver daily, but I don't want the task to be seen on the main window. Is there a way to do that?
Thank you in advance,
Snow.
Hide a task from the main window
Re: Hide a task from the main window
Do you want to hide a profile from SyncBackFree's main-interface? If so, I'm sorry it is not supported.
Can I use the portable version, install it in the flash drive, and start the application with 3 clicks? I think it's the better solution, the pc installed version, will continue to backup automatically, and my pen drive will backup manually and "hidden" from the main interface...
