SyncBackFree for VISTA
marval
Post by marval »
I have an old computer running on VISTA on which I saved the SyncBackFree set-up. The set-up does not activate (I have repeatedly downloaded from the internet). Any ideas? Thanks!
marval
Re: SyncBackFree for VISTA
Can you please download and install SyncBackFree (v7.6.50.0) from here to see if it helps:
