Can I use SyncBack on Windows XP?
mats
Post by mats »
Can I install and use SyncBack (free version) on Windows XP (Service Pack 3)?
Re: Can I use SyncBack on Windows XP?
Sorry, but SyncBackFree/Pro/SE are not officially supported on Windows XP.
You can refer to the KB article for SyncBack system requirements:
http://support.2brightsparks.com/knowle ... quirements
If you want you can download SyncBackFree from here and test in on your end to see if it works:
However, we can't offer support to solve issues/errors that occur with the use of SyncBack on Windows XP, as it is not officially supported.
