Newbie questions about syncing
mwr
Post by mwr »
I currently backup my desktop (Windows) computer to an external hard drive using WD (Western Digital) SmartWare. It backs up fine, including all the thousands of temp files created, but doesn't remove those temp files from the external hard drive when they are automatically removed from the computer. So I have to do that via a bat file.
I'll soon be getting a new laptop to replace my tower desktop computer and want to get it started right. I'd like to backup to the external hard drive but also have it sync to the laptop so that when any files on the laptop are deleted, moved, or renamed, that is automatically done to the external hard drive. Is that what 2BrightSparks software does?
I'd also like to backup (sync, as above) to the cloud. Would 2BrightSparks software do that?
What version of 2BrightSparks software do you recommend for me?
All comments appreciated!
Re: Newbie questions about syncing
Only SyncBackPro supports backing-up files to cloud services (like Google Drive, OneDrive, Dropbox etc.,). You can see the list of cloud service that are currently supported by SyncBackPro here:
http://www.2brightsparks.com/syncback/compare.html
Therefore, you can create a Mirror or a Intelligent Synchronization profile in SyncBackPro to sync files from laptop to an external drive/cloud server.
Note that a Mirror profile will copy all files within scope from your Source that are 'absent' or 'different' on the Destination and delete files/folders on Destination which are deleted on the Source as well, thereby making both Source/Destination a 'Mirror/1-to-1' set of each other. However, a Intelligent Synchronization profile in SyncBackPro copies, deletes files in both directions, but it also keeps a history of where files were during the last synchronization. Briefly, a Mirror profile type is 1-way synchronization, whereas Intelligent Synchronization profile is a two-way synchronization (so use this profile type only if the files are changed on both Source and Destination).
You can refer to this article for the step-by-step instructions to create and schedule your first profile in SyncBack:
https://www.2brightsparks.com/resources ... setup.html
And read this article for the steps to create a Google Drive profile in SyncBackPro:
https://www.2brightsparks.com/resources ... drive.html
In addition, please read the Help file > Using SyncBackPro > Basic Operations > Creating a Profile and Running a Profile for the detailed steps to create and run your first profile. With SyncBackPro opened, press F1 to open the contextual help.
If you want you can evaluate SyncBackPro, which we offer a free 30-day evaluation. You can download and install latest version from here:
mwr
Post by mwr »
Thanks for the very good reply. From your description, I'd be using a Mirror profile, changing only the source and wanting the destination(s) to be exact copies of that source ("synced" with that source).
How would I decide on which cloud service to backup/sync to? Do you have or know of good comparisons of them?
Sorry, but we can't provide suggestions on which cloud service to use as this is beyond the scope of our support. However, you can refer to "Pricing Comparison between cloud services" section of this link for the information about the free storage available and the price plans for different cloud services supported by SyncBackPro:
https://www.2brightsparks.com/resources ... -2016.html
If you have further questions, please contact us directly through our support ticketing channel ([email protected]).
