I have a sync profile (Backup mode) to copy my Documents folder to an external LAN drive. It is working just fine with one exception. I created some new folders recently to re-organize my photo collection. Naturally, the first run took a while to completely copy the folder contents. But now, whenever I run the profile, there are 13 JPG files which SyncBack reports need copying (again) - even though I have not modified them. I go ahead and select continue, and it completes normally. I can check the logs, and there are no reported errors, and it shows the 13 files being copied.
However, if I re-run again immediately, it finds the same 13 files and wants to copy them again. I can repeat this over and over and get the same results. It seems obvious that IT IS NOT copying these files even though it says that it has.
The files are not locked, they are not Read Only, they look perfectly normal, just like the other hundreds of JPGs in the same folders.
I'm stumped.
George
