Failed to copy from source, can't change temp name.
lgolebio
Post by lgolebio »
Hi
I'm using SyncbackFree on my Windows 7 machine. I created profile to "mirror" backup of my folders to a NAS server. I have a QNAP TS-212P.
Everything is working OK but sometimes I get:
Failed to copy from source : Safe copy Failed. failed to rename temp file: File is locked (\\NAS\xxx\xxxx\SBSE____.DO4) The process cannot access the file because it is being used by another process.
It doesn't matter if it is a .pdf, .doc, or .jpg file. Does this mean that my QNAP is locking this temporary files somehow ? It's weird because 99% of files are being copied and from time to time 1% gets this error.
Re: Failed to copy from source, can't change temp name.
Based on the error message it appears that some other process running on your system has locked (or has handle) on the safe copy file (SBSE_____.XXX) created as a part of the safe copy process, hence SyncBackFree failed to rename the temporary file (safe copy file) to the actual name after copy was success.
You can refer to the Help file > Copy/Delete > Advanced settings page to understand about safe copy option and why this option is enabled by default.
As this error is returned when renaming the safe copy file, you can try switching off the "Make safe copies" option under:
Modify > Expert > Copy/Delete > Advanced settings page
to see if it helps to resolve your issue.
lgolebio
Post by lgolebio »
Is this safe to switch this options OFF when the profile is set to "mirror" ?
