Run from Command Line Asynchronous
When I run SyncBackFree from the command line it appears to run asynchronously. However due to some sequencing of events, and checking that needs to be done I'm wondering if it can be made to run in a Synchronous mode, ie the command will only exit ones the profile has completed.
Re: Run from Command Line Asynchronous
Hi - have you considered using the START command with the /WAIT switch to trigger SyncBackFree > the profile?
NOTE: there is apparently a bug in the START command when double-quotes are used so that the program path\name is treated as a 'title', and any following parameters you specify (such as a profile-name...) are wrongly treated as the program command (which will obviously fail). The trick (and more details), according to
http://stackoverflow.com/questions/1540 ... ed-program
is to add/use a dummy title as a/the first quoted-string (note: there's a comment in the stackoverflow thread that mentions empty double-quotes as a dummy title can give errors but it worked either way for me in Win10...). I used something like
START /WAIT "DummyTitle" "C:\Program Files (x86)\2BrightSparks\SyncBackFree\SyncBackFree.exe" "test Profile Name"
DIR P:
and it works fine in a batch file for me. The DIR command is there only as a visual clue if/when next-stage happens, and the START command definitely waits for SB to close before executing the DIR.
Please note: I am by no means an expert DOS programmer; using START /? (to get contextual Help) gives me a migraine (note that the 'title-bug' still isn't mentioned or mended yet). Ditto most of the stackoverflow article, if I'm honest. I doubt I can give you any deeper assistance if you have problems, but the code above seems to work for me...
DIR P:
