*Almost* backup configuration
Jim Wilson
Post by Jim Wilson »
I'm struggling to implement the following rule:
copy the file from the Left to Right only if the file is (A) not on the right, or (B) the one on the left is newer
Is this easy and I'm just not getting it? Or is it harder than I think?
Re: *Almost* backup configuration
HI, it's not available in the freeware version (nor in the upcoming SyncBackLite V8, it appears). But you can do it in the SE & Pro V7 (also V8 BETA) 'commercial models' by
a) creating a standard Backup* profile and then adding the extra setting >>
b) Modify profile > Expert view > Compare Options > Date & Time > 'Do not replace newer files with older files'
Otherwise, your freeware choices (to cover the situations where a copy of a file exists on both sides) are (as you probably worked out) >>
1) set it so that, in effect, 'Source always wins, regardless of date/timestamp' (the default Backup or Mirror rule) - or
2) set it so 'newer file overwrites older file (synchronise)' (which might mean 'Right wins & overwrites Left file')
(assuming you don't want to base any decisions on size...)
* or, a standard Mirror (Left to Right) with the same extra setting (depending what you want to happen with Destination-only files - you didn't say)
Jim Wilson
Ok, thanks for the answer. I appreciate your time.
