Stupid question maybe...
I would like to know if it would be possible to sync, mirror or whatever files contained in several subfolders without mirroring these subfolders.
For exemple a Folder #1 which contains subfolders A, B, C and D, each one with one file (a, b, c and d), would be mirrored (or sync) in Folder #2 which would contain only files a, b, c and d, but without subfolders A, B, C and D.
For those who are looking for this feature, after a day of search, I have found this very useful tool, FolderMerger which does the work easily and efficientely.
Unfortunately, it requires a manual input before letting SyncBack doing its automated job...
But perhaps, it could give a good idea to the developpers !
