SyncBack BETA V8.1.0.0
Post by mickyj »
SyncBack BETA V8.1.0.0 is available for download:
Pro V8 32-bit: https://www.2brightsparks.com/assets/so ... _Setup.exe
Pro V8 64-bit: https://www.2brightsparks.com/assets/so ... _Setup.exe
SE V8 32-bit: https://www.2brightsparks.com/assets/so ... _Setup.exe
SE V8 64-bit: https://www.2brightsparks.com/assets/so ... _Setup.exe
Lite V8: https://www.2brightsparks.com/assets/so ... _Setup.exe
Free V8: https://www.2brightsparks.com/assets/so ... _Setup.exe
Changes in this version:
New: Start the task only if the computer is on AC power option added to scheduler
New: Proxy server support for email
New (Pro): Support for Google Team Drives
New (Pro): Option to automatically (or not) translate invalid filenames for the cloud
Updated: Korean translation
Updated: Simplified Chinese translation
Fixed: Uninstall bug (multiple prompts and access violation)
Fixed: Other minor fixes and updates to help file
Fixed (Pro): Could not switch off delta API for OneDrive for Business and SharePoint
Fixed (Pro): Could not select to upload cloud database for OneDrive for Business and SharePoint
Fixed (SE/Pro): Log file now shows information for VHD instead of drive VHD file is on
Fixed (Pro): Improved uploads for OneDrive Personal, Business and SharePoint
