SyncBackFree V8.1.1.0 released
SyncBackFree V8.1.1.0 has been released. See the history of changes page for details.
Re: SyncBackFree V8.1.1.0 released
Hello, I am not a computer savvy person but I do have a basic understanding.
I have been using SBFree for a few years now and never really had any backup problems. I downloaded this new upgrade yesterday and then did a backup. I now have 2286 errors showing on my C drive backup the most I've ever had was somewhere under 20.
So scored a failure on the backup. I backed up a smaller F Drive and had no problems.
There are two files that the log says are the main offenders, 2251 errors:
C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppHang_iphlpsvc_7362df3620acdb723b5245c74e2f3bea62710be_0dc2ace1\ Scan failed (5): Access is denied
\ProgramData\Microsoft\Crypto\RSA\MachineKeys\0452b139c0028863b533d8e09a51b305_e4f9e5a0-bdbe-4875-be56-edcfe80a2484 Failed to copy from Source : Cannot copy file (5): Access is denied
Is there a reason why these files are now non compliant with SBFree?
Is this a SBFree issue or something that has changed on my computer?
What can I do about it?
At the last backup on 30-04-2017 there were no issues on either drive.
I am using windows 7 home premium "32bits" I think.
I realize this isn't a direct answer, but FWIW the WER directory contains nothing of use to your computer. It exists for error-reporting to Microsoft, and ostensibly for them to get back to you with answers (Don't know if that ever happens, because I turn it off).
Source
The MachineKeys folder OTOH is used to validate server/internet connections, and has a known issue with occasionally running amok. It's useful at the moment the file is created and used, but not later. If ANY service on your computer is currently talking to the internet when Syncback tries to copy, it might have that file momentarily locked, which would cause a copy error. Again, this isn't meaningful to your computer from a restore point-of-view; you can delete the entire folder and the contents will be recreated as needed.
Source
I don't know why 8.1.1.0 is causing errors you never saw before, but it might be coincidental. Anyway, my answer, without addressing SB itself, is that you can safely exclude these directories from backup.
Frankly, when I try to back up my C:\ drive I get MANY uncopyable (locked, in-use) files, so I'm amazed you don't have more errors like I do.
Source
Source
