change pathing from \\server\share to just drive letter
derohero
Post by derohero »
Howdy,
Syncback free, current version, I believe when you first set a path to a network drive letter, it asks you the question about switching the drive letter to the \\server\share. I probably said yes to that, but now I would like to say no. So, when I do backups on a network drive, I want to use the Drive Letter only and not the server name etc... My reasoning is because I do it in 2 different places at the same path..
Is there a handy ini file or reg hack that might return that question or just have it quit switching the drive letters?
Thanks, Jon
Re: change pathing from \\server\share to just drive letter
[A little background for other readers: I assume you clicked 'Do not prompt me again', having chosen Yes in answer to the prompt question. You've now set a program-level ('will affect all profiles') pre-answered Dialog to silently use your preferred answer, instead of appearing/asking next time]
To reset it...
Preferences menu (main UI) > Dialogs > click the profile selector drop-box at foot of dialog and select (click) the entry *Program*
One of the options listed for *Program* will be one that looks like
[x] Would you like the path for %0.s changed from %1.s to %2.s | Yes
Uncheck it, OK out, and the original behavior will return.
Note: mapped drive letters can cause issues of their own, one of them being that the mapping generally doesn't work when run on a Schedule (see para 2-4; para-1 won't apply to you if using Free but you may want to read it out of interest)
PS (for all/any readers): selecting *Program* applies in the above case, but may be a profile-level question in another case. If so, instead of selecting *Program* in the selector box in the dialog, select the actual profile name whose Dialog you want to change the default behavior of
derohero
Post by derohero »
Excellent, that works perfect.
Another thing I noticed was I could go in to users appdata local 2 brightsparks folder and edit the .ini of the particular job, modified the path in there (while the app is closed) and then opening the app back up, it stays with the drive letter.
So noted about the path issue if I use scheduling, I will be sure to use \\srv\share.
Thanks for the quick reply! SyncBack is awesome. Jon
