If you are using V8.2.8.0 then update to V8.2.11.0
If you are using SyncBackFree V8.2.8.0 then update to V8.2.11.0. There was a bug in V8.2.8.0 that could stop scheduled profiles from running.
Re: If you are using V8.2.8.0 then update to V8.2.11.0
I'm using Win 10 64-bit and the latest version of SyncBack. The scheduled backup always gives an "aborted by user" message. Manual run works OK, as was everything in Win 7.
