Currently i have a syncbackfree program running for a friend. They have 11 profiles for backing up data. Each of the sends an email report upon completion. However about 4 days ago there was a weird issue. Every backup starting sending duplicate reports. Now instead of 11 backups my friend reports 21 results. I upgraded him to the newest version on the site V8 from the V7 he was on still happening. I also saw that all the backups in the scheduled section have what seams to be duplicate runs, not sure if this is just how it normally displays, never noticed it before.
If anyone needs more info to diagnose this give me a shout.
Thanks in advance!
Duplicate Syncback reports
Re: Duplicate Syncback reports
Anyone know about this??
It's not clear what you mean by
Nor is it clear what might have caused this, but it might be a recent Windows 10 Update if your user is running Win10 (you didn't say)? Recent Win10 Updates have been messing with the Windows Task Scheduler ( a lot...) without documenting it, but frequently breaking things...
But it does seem as though you are currently Scheduling all the profiles individually, whereas things would likely be less complex all around if you used a Group (create New Profile, give a unique Name, check 'This is a group profile', click Next, then add all the other profiles to it in the order you want them to run. Do NOT click the 'parallel' option in the Group's Modify window (F1 with Group's Modify window open for 'why not') and OK out to save it)
Now, delete all the Schedules you can see from wherever you are viewing them. Now return to the SB main UI, right-click the Group, click Modify, click When and Schedule the Group. Wait overnight and see what happens...if you still get multiple runs per profile, post back with more detail on where you see the (still plural?) schedules, preferably with a screenshot
and you didn't provide a screenshot. It's not normally possible to view more than one Schedule at a time from the SB UI, and certainly not 'more than one per profile'. Are you referring to the Windows Task Scheduler's own interface?the scheduled section
Thanks Cliffhanger for your reply.
Apologizes about the lack of screenshot. Yes they are running win10. All the scheduling has been down from within Syncback.I'll attempted the Group work around and will report back if this works or not.
cliffhanger wrote:It's not clear what you mean byand you didn't provide a screenshot. It's not normally possible to view more than one Schedule at a time from the SB UI, and certainly not 'more than one per profile'. Are you referring to the Windows Task Scheduler's own interface?the scheduled section
Yeah looked in task scheduler and saw double tasks for every backup we had. Removed those know and till check tomorrow. Thanks again!
If there is an ongoing problem with the Windows Task Scheduler (so that 'just happening' to duplicate all the 2BS Scheduled Tasks (possibly by duplicating the entire custom 2BS/SBF task folder) wasn't a one-off, and it's going to do it again at some point), you might end up with two Group schedules (triggering at the approx same time) instead. I have no idea how to cure that if it happens repeatedly.
Cheers bud,cliffhanger wrote:If there is an ongoing problem with the Windows Task Scheduler (so that 'just happening' to duplicate all the 2BS Scheduled Tasks (possibly by duplicating the entire custom 2BS/SBF task folder) wasn't a one-off, and it's going to do it again at some point), you might end up with two Group schedules (triggering at the approx same time) instead. I have no idea how to cure that if it happens repeatedly.
I've removed all the scheduled tasks and am now creating them all with a group profile. Can you add existing profiles to groups or do you have to do this when you first create the profile?
Yes, you can add (or remove) profiles from existing Groups; just Modify the Group (e.g. right-click Group > Modify). With the Group open for Modification, you can press F1 for more info and also switch mode from Easy to Expert (using options top left), where Expert mode reveals more settings you could use & Easy mode shows only the basic ones. Many of the sub-pages for settings have their own Help, so keep that F1 key handy...
