Change password
aliccam
Change password
Post by aliccam »
I wonder if someone could tell me how a password can be changed within SyncBack Free
if the Windows password has been changed?
I searched everywhere but haven't found a clear answer anywhere.
Re: Change password
Hi, change password where in SyncBackFree? Do you mean in a Schedule? If so, there's no way of editing that direct from inside SB (except by deleting & then re-creating the Schedule) - you would need to access the Windows Scheduled Task/s that SB created for you and edit the password there.
Actually changing a password in a Task isn't a clickable option via Windows either - you have to provoke it into asking for the password then supply the new one. Luckily, if you have the new-style Scheduler (Vista-and-later) and you also have multiple Schedules, you should only need to change the password in one of your Tasks; this will propagate to the other Tasks by changing the single centrally-stored copy of your password that modern Windows uses for all a given user's own Scheduled Tasks.
aliccam
Re: Change password
Post by aliccam »
Thanks, cliffhanger, very much.
Well, all this is not exactly straightforward. What a shame.
I suppose it would put people off from changing passwords frequently
which is what they are supposed to do.
All the best.
